Results 1 to 8 of 8
Thread: How long should I run the pump/filter?
    lulupalooza's Avatar
    Mar 2008
    Evans, GA
    323
    My apologies if this has been posted recently as I think it has, but can not locate the post/thread. But approx how long should I be running the pump/filter each day? So far its been running almost 24 hours. Since its a new set up/fill and I am just adding chems. Do I need to keep it running or can I say shut it off at night and then cut back on in the morning?
    TYIA
    *~ Laura ~*
    27x52 Aquasphere Conquest AGP (approx.17,100 gal)
    1 HP Pentair Dynamo Pump & SD-40 Sand Filter
    TF-100 Test Kit
    BBB User- Salt Added
    How long you need to run the pump depends on the relative size of the pool and pump and is tricky to calculate. It is usually much simpler to try out various run times and see how the water looks. 12 hours a day is a good place to start and then adjust up or down from there depending on how the water looks.
    Butterfly's Avatar
    South Carolina
    10,045
    You'll get lots of different answers on this one!
    Every pool is different. For our pool, we run our pump appx 3 hrs in the morn and 3 hrs in the eve. (Average 6 to 8 hrs per day).
    Doing what Jason suggested, starting with 12 hours and adjusting from there is a good way to go. Then you'll find what works for your pool.
    btw, our pool water sparkles!
    Happy swimming
    You're done SLAMing when:
    Mar 2007
    Richmond, Va
    182
    so, along those lines, if you run it just 12 hours is there a "best" time? Better to run overnight or during the day?
    18 ft.52" Round Atrium AG -7600 gallons, Sand Filter, Vinyl liner, Royal Entrance Steps, 80 lbs.solarsalt
    There are many different criteria for what times of day are best to run the pump and they tend to contradict each other to some extent. In the end any choice is a compromise between different factors.
    Some of the issues to keep in mind include:
    * Running at night costs less if you have time of day based electric pricing
    * Running during the day is best for solar heating
    * Running during two or three different periods spread across the day/night is better for maintaining circulation
    * Users of a SWG or Liquidator are slightly better off running when there is direct sunlight on the pool
    * Many people prefer to have the pump running when they are swimming
    * Running at night, particularly with jets/fountains/waterfalls going can help cool the pool in hot climates
    Butterfly's Avatar
    South Carolina
    10,045
    Good point, Waterbug.
    Some folks run at night because of the better elec price.
    Some run at night during the heat of summer because they want to cool their water.
    We run morn and eve and sometimes all during the day when I forget to turn off the pump.
    However, we never run at night. DH just won't do it!
