Drifter's Paradise
Feb 17, 2012
52
Memphis, TN
wassup TFP? Really glad I found this site and figured I start a thread of my own.
Im a first time pool owner and have been following the BBB method since may of this year and everything has been great until recently..
About 2 weeks ago, the pool went from sparkly blue/clear to green. I followed the shocking process and kept it above shocking level (+20 fc @ 45-50 cya) until it passed the OCLT. it got to the point where i could see the drain pretty well so i let it drop to normal FC levels. well a couple of days ago, it went white cloudy again but it didn't drop any FC over night with 0 cc. Do you think I need to bring it back to shock level again? just really confused because everything is checking out like it should but it went cloudy only in the deep end :hammer: . I did notice that my main drain isn't working as well as it should since it is missing the skimmer diverter. could this be the reason why it started to get cloudy again but not green? i am seeing green spots in certain spots of the pool after a few hrs too and easily scrubs away.
shot of my backyard oasis
Nothing in you test numbers suggest a problem with calcium clouding.
I missed you comment about green spots. That does suggest you need to coninue with the shocking process. Are the spots on the sides or the bottom?
Took your advice and pulled the light out. There was a cloud of green algae that came with it. Could that be the reason it won't go away? I've been shocking for a few days now and its still the same. Clear at the shallow end and cloudy in the deep end with green spots popping up at the same areas after 5 or so hrs. Pump has been on 24/7. I've been brushing constantly too.
Keep up with the shock process and don't let your FC drop below your shock level. Chlorine needs to kill all the algae and you should be seeing some positive results everyday from here on out. Keep your FC at or above 20 for a CYA level of 50. Try to target 22 and see how long it can maintain it at that level.
well it's been sitting at about +24 fc for a few days now with no signs of it getting better. what's strange is that it tests 0 cc and less than .5 fc drop overnight. usually 0 drop! the same spots always reappear after about 6-8 hrs with the pump running 24/7. im started to think that might be mustard algae. they are clumps of dark green/yellow at some spots. i've read the mustard algae section of pool school and i think im gonna raise the fc up to MA shock level. ill try to post some pictures of it tonight.
