- Aug 19, 2011
- 23
I am crazy happy with the results of my pool this year so far:
Temp 86
Salt 3800
FC 5+( my taylor 2006 tops out at 5)
PH 7.5
TA 80
CH 70
CYA 50
Borates 50
So far after adding Borates, 1 month ago, all I adjust is Ph every now an then to lower 0.2 points. My question though is my FC: I run my pump 12 hours (2Am-2PM) and my Hayward GoldlineSWG with T-3 cell is set at 35% output. Should I be concerned that my FC levels are ALWAYS 5+? As water temp cools I turn down the SWG %...but how low can you go?
I have a taylor 2006 and another quick PH FC that I used and both return the same value. Does the T100 kit allow reading over 5?
Any help is appreciated
Temp 86
Salt 3800
PH 7.5
TA 80
CH 70
CYA 50
Borates 50
