Thread: Pentair Easy Touch
    Apr 2008
    San Carlos Mexico
    45
    Pentair Easy Touch
    I have an intellifo 4 x 160 and a pool pilot digital SWG. Will the Easy Touch comunicate with the pool pilot or do I just set it to come on with all the pump cycles.
    30,000 gal Pebble Tec, Intellifo 4X160, Pentair 80 DE Quad, Pool Pilot SWG, Easy Touch Controls
    Jul 2007
    Sahuarita, AZ
    278
    I vaguely remember seeing a thread on this a long time ago (you might try to search)... If I recall correctly, the digital communications between the EasyTouch and the Pool Pilot are not compatible. At the very least you'd have the pool pilot wired off the easytouch relay which powers your pump. This would cause the SWCG to run whenever your pump runs, but you'll probably have to set levels manually on the pool pilot itself. We have a few SWCG experts on the forum and I'm betting one of them will chime in with a more definitive answer soon.
    My Pool:
    12K gal IG gunite with 7' raised spa, gunite waterfall, PebbleTec Caribbean Blue finish, solar heating & in-floor cleaning system
    Equipment: Sta-Rite 300' Cartridge Filter, Intellichlor IC20 SWCG, Sta-Rite 400k BTU heater, Intelliflow 4x160 main pump & Sta-Rite 3/4 hp waterfall pump, EasyTouch controlls w/ wireless controller, TF-100 Test Kit w/ salt test.
    I believe they can be wired up if you can find the correct cable. However you lose temperature compensation so it may be better to simply switch to AutoPilot on and off with the pump.
    Apr 2008
    San Carlos Mexico
    45
    Thanks for the input i think I will just go that way
