New Intex pool owner questions
pensfan
you can order just the fas-dpd chlorine test from tftestkits , it is very cheap and you will have everything you need to accuratly test fc and cc and use your test strips for ph,alk and such if money is a issue and you will have it in a couple of days, i don't reccomend blindly dumping chemicles in a pool......jmo......Mike
yep i blindly dumped in bleach, in my mind with the calculations i did i should have kept it way over the shock levels for over 30 hours, but i'm sure it was the alcohol talking when i started thursday night. I am going to let the FC levels come down now and see if i can hold that at 6-7 min. If i am still having an issue i am going to order a test kit.
Hiya PAGirl. I see Pennsylvania is well represented here.
