Hello from Alabama
Aug 5, 2012
3
We have had our pool for about 6 years now and have had off and on issues with green algae. Up until 3 weeks ago, we have always been able to get control and have crystal clear water. We have shocked and shocked to no avail. Our pool used to be shaded and now we have full sun ( we cut the tree down).
I tested the water this morning using our K-2005 test kit
pool size is 20X40 lagoon style in ground vinyl liner
FC .5
TC 1
CC .5
PH 8
TA 150
CH 290
CYA 90
Temp is 85
We are just really stumped, we have put in algaecide, shocked the pool, backwashed the filter, added water. We have had several weeks now of high temps, high humidity and a fair amount of rain.
Any advice is appreciated.
Thanks
Welcome to the forum :wave:
Based on your test results, your pool is overstabilized - CYA is too high. I suggest that you do the water dance (series of drains/refills) to replace about 44% of your water to lower the CYA to about 50ppm.
After that, you can retest everything and see what else needs adjusting prior to starting the shock process.
Well it's been almost a month and just yesterday the water finally turned blue again!!! I am sure some bells were ringing somewhere. So here is the latest numbers:
FC-6
TC-3
PH 7.4
Alk 70
CA hardness 200
CYA 40
We have a 36000 gl
vinyl liner
Do you think we are finally stable now, it seems so but thought I would ask. Thank you for this site, it was a life saver in getting rid of the algae.
