Anyone have experience with the Poolsmith Organic pH system? I'm using a lot of MA with my SWG pool and I'm looking at pHtek proportional feed system, or the Poolsmith setup. I'm leaning towards Poolsmith even though it's a couple of hundred more.
The main pro's I see are: change out cylinders only every 3mo+; no need to use acid; more natural; set it and forget it (still plan to test once a week)
Cons: cylinders are heavy to lug around and get refilled; I'll need to inject using cleaner pump as the Ozone is connected to main pump.
I have read about TA rising with use of CO2 but after lots of research, this appears to be a common misconception and not really factual.
Any other pro's/ con's I should consider?
