Aquarite SWG no power
Aug 3, 2012
2
East Tennessee
Need help with Aquarite system (1 year old). Replaced ICL (AS32-2R025), standard item from digikey. Original was cracked and fell apart when touched. Plugged in, and immediately blue main 20A fuse. Possible problems? Poor soldering job (first time)?
The standard ICL of other threads is the SL32. IT has the .024Ohm resistance at current wher the AS (Amertherm) is .0185Ohm. Also, larger tolerance of 25% as compared to 15%.
The Amertherm was what was in the board.
Thanks.
