Tried drain and circulate, no water is moving at all. I also checked again to make sure that nothing is obstructing the impeller.
BeanTree said:So it is possible that the impeller is spinning but just too slow?
You cannot see the impeller itself with the basket lid off.
techguy said:Yes, if the impeller broke loose of the pump, it could spin the motor freely without any water resistance but not pump water.
This is why I suggested the tube cut. Prove the pump...pumps water when installed.
jblizzle said:But running on Waste is basically the same thing (assuming no clog in the multi-valve).
I just have a feeling it is not spinning at 3400 rpm OR the impeller is completely plugged to see no churning in the pump basket.
vsyzer said:looks like the impeller is broken
BeanTree said:Ok looking at the parts list from a dealer, we may have found the problem. I think what I thought was 2 pieces is actually supposed to be ONE piece!
http://www.poolandspastuff.com/PumpPart ... terAce.htm
check out that impeller. What they show, I have in 2 parts. That would explain this. Now...to get this o
