Thread: Pentair VF De-Rated?
    stever's Avatar
    Nov 2007
    Escondido, CA (near San Diego)
    285
    I saw a reference on another forum about the VF being down-rated recently from 160 GPM to 130 GPM. I can't however find and backup for this statement. Anybody have any insight on this? If so, would this also hold true for the VS?
    http://ths.gardenweb.com/forums/load/po ... 06.html?13
    Steve
    Pool: 625 SF Free-Form In-Ground Shotcrete Pool w/7.5' dia spa.(8 jets), 24" raised bond beam (22,500 gal)
    Pentair Equip: Intelliflo VF Pump, MasterTemp 400 Heater, IC40 SWG, Quad DE 100 Filter
    Automation: IntelliTouch i7+3 (+ extender panel), 6 Jandy Automated Valves (S, R, Spa Bypass, Solar, Cleaner, Spillway)
    Other: 75% Solar, Kreepy Kruiser Cleaner, Tan Hip-Hop Diving Board (a bit curved) on 606 Cantilever Base (SR Smith)
    Links: [TFP Pool Build Thread] - [TFP Landscaping Thread]
    I have never seen Pentair claiming 160 GPM for either IntelliFlo, or 130 GPM for that matter. Their pump curves go out to around 147 GPM under ideal conditions. In any given install you are unlikely to reach that ideal flow rate. 130 GPM is a more realistic guess at what can be reliably and efficiently achieved in real world situations.
    stever's Avatar
    Nov 2007
    285
    Point taken -- I was more concerned with a reduction than the specific numbers. I fully agree that theoretical maximums mean nothing -- I must merge my specific pool specs (head) with the curve. Thanks.
