Thread: Dont know if I have metallic parts in heater and valves??
    Plano, TX
    110
    I'm installing an in-line chlorinator that states I need a check valve to prevent corrosive backflow if I have the following:
    -preceding valves constructed of PVC or other plastic with metallic shafts
    -heaters or other items with metallic tanks, shafts, coils, or tubes.
    unfortunately, I don't have a clue...
    I'll attach a link to pictures of my valves and heater. The heater is a Hayward H400 lDL2 lo-nox 400,000BTU unit installed in June of 05 if that helps. I've read over the info on the hayward site, and I still am not sure. As for the valves, I guess I could take one apart, but if someone knows if the shafts are metallic, it would be great!
    http://i71.photobucket.com/albums/i159/ ... 030249.jpg
    http://i71.photobucket.com/albums/i159/ ... 030251.jpg
    28K IG, stonescapes pebble, raised spa, hayward heater, Pentair Intelliflo, Pentair 60ft DE filter, built around 1980, remodeled 2007.
    The heater has metal in it and counts for sure.
    Plano, TX
    110
    okay, thanks. I guess it's probably a good idea anyway...
