You add the amount of chlorine based on your test results. The amount, in ounces, is also dependent on the concentration. In example, if you need 10 oz. of 6%, you could use 6oz of 10% or 5 oz of 12%. They are all essentially the same chlorine chemical with more or less water.
The pool calculator.com is the easiest way to figure it out.
