Finally got the pool filled, pump running, and a full set of test results. Anything I should keep an eye on or start worrying about?
FC: .5 at sunset (added bleach per pool calculator, circulated, and rested. Now 4ppm)
CC: .0
PH: 7.2
TA: 300 (I tested using 10ml sample so 25ppm per drop and got 12 drops before it changed color)
CH: 300
CYA: 0 (its in the sock soaking, added 3lbs per pool calculator for a target of 60ppm, i'll check in a few days and make final addition)
Salt: 3200 per pool calculator (don't have any test strips for salt, going to start the SWG tomorrow to get it dialed in on run time)
I know my TA is extremely high, add that to the SWG and I know I'm going to have to keep an eye on my PH level (jug of MA ready to go). Anything else I should be focusing on at this point?
CC: .0
PH: 7.2
CH: 300
