Help me identify this valve
Jun 3, 2007
151
I believe this is a check valve... and it has a cracked cover causing a slow leak. I'd like to find a rebuild kit, but I'm not sure who made it. Unfortunately, the PB put the plumbing for this valve under concrete decking leaving no easy way to replace the entire unit. I just have a 6" access cover to work with.
Anyone know the manufacturer?
[attachment=0:3stdz2m3]2012-06-30_16-58-04_40.jpg[/attachment:3stdz2m3]
Thanks!
What is the other word besides Lock?
Have you taken the screws out to see what the inside looks like?
The top kind of looks like the Jandy/Pentair check valves, but I have never see the twist thing/gear on the top.
I think the other word is "unlock". This happens to be my friends pool and I'll need to ask what it says to be certain... but pretty sure it's "unlock". If no one recognizes this thing taking it apart would be our next step.
Thanks.
Here is picture of the inside. It turns out it's a regular 3-way valve, but with no identifying markings anywhere. How is a guy supposed to get parts for this POS? Perhaps this may help someone recognize the thing. You can see on the ground a jandy valve i brought over to see if it would fit. It doesn't.
[attachment=0:2ne4nnoj]20120713_091935.jpg[/attachment:2ne4nnoj]
