Fountain heads/nozzles?
shakenbake
204
Austin, TX
I've been looking everywhere for more interesting fountain nozzles fort he kids. My PB put in three fountains, that are essentially a screw-in PVC pipe with a regular 1.5" return eyeball on the end.
I was thinking there would be all sorts of nozzles one could screw in, but the the life of me I can't find them.
Any ideas/pointers?
Thanks guys. That's not quite what I had in min but great options.
The PB put a standard 1.5" eyeball return in the floor of the hot tub and kiddie pool. Then they put a PVC extension into the threaded return receptacle and put the eye-ball on the end of it. I can screw in any standard return nozzle into the end of this PVC. To me this would be as simple as deciding you want different hot-tub jets....but I can't seem to find any nozzle designed to be fountain heads.
This is the nozzle I have now (similar) http://commercialpool.com/returnfitting1534eyeball.aspx
Could you take something like this http://www.epoolshop.com/1-12pipeplugwitho-ring.aspx
and drill small holes through it to make your fountain?
