when using a floc, your gonna get much better results with dead algae. Which means your gonna have to shock, and be diligent about your free chlorine levels. Algae multiply fast, and by the looks of your photos, the kill rate seems to be much lower than they are able to multiply. Like any opponent, you have to know their weakest point, in order to defeat them. Algae, being a plant species, can only multiply in sunlight due to photosynthesis. So, this means the time to attack is at night, especially if you want to get a good head start. Sundown is the best time to start a good "shock" therapy on your pool. Before you start, the most IMPORTANT thing to add to your pool right now is PATIENCE, and realize this process may take anywhere from 24 hours to a week to accomplish optimum results and levels. Also keep your filter/pump running 24/7 during this process. So, here we go. TA (alkalinity), CH (hardness), and CC (combined chlorine) are not going to be important right now. The two things your gonna need to keep in check is PH and FC. You want to get your PH down to 7.2 and no higher. Do this at least few hours before sundown tonight, and test it every half hour to make sure its holding steady. If it rises, add muriatic acid. Use the chart on
http://www.poolcalculator.com/ for how much, based on your pool size/water volume. You may find yourself adjusting PH quite often during this battle. DO NOT ADD any chlorine yet, until sundown. Now, at sundown. Prior to adding any chlorine, do a CYA test. Once you get your CYA level, use this page
http://www.troublefreepool.com/pool-school/chlorine_cya_chart_shock to find out your shock level. This level is going to be your FC (free chlorine) level, and you're going to have to maintain it constantly. Once again, use this site
http://www.poolcalculator.com/ to find out how much bleach to add, to achieve shock level. Double check the chlorine % on the bottle when using the calculator, so you can get an accurate dose. Use liquid bleach, no tablets, or powder. After adding recommended amount of bleach, wait about 20 mins to half hour, and test again. PH first. Now, this is where it may get weird. Some drop tests are sensitive to high chlorine levels. You may get a false reading depending on how high your FC level is. Don't worry if you get a low PH reading after adding the bleach. Liquid Chlorine will not cause a drop in PH, it's just your test being sensitive. But, if your test is not sensitive, you won't experience this. In fact, you may see a rise in PH, due to the organics being killed by the bleach. If this is the case, adjust PH accordingly (7.2). Again, use the pool calculator. After PH is adjusted or confirmed to be no higher than 7.2, test for FC. If FC is lower than your "shock" level, adjust accordingly. Use the pool calculator. Now, before going to bed tonight, do another PH and FC test, just like before. Adjust accordingly. Once again, you've got keep the filter/pump running overnight and 24/7, so keep it running. Tomorrow morning. The optimal time for tomorrows test would be just before sunrise, or before any direct sun exposure to your pool. So depending on your schedule, plan for an early rise
. We're gonna do the same PH/FC test like last night, and the same adjustments also. You're going to have to keep on this, which means every half hour to hour, testing the water. I would recommend every half hour while the pool is under direct sunlight. The monotony will pay off in the long run.
It may be wise to show some in the family what your doing, in the case you cannot be home during the entire process. Also, keep in mind, just PH/FC right now. What we are looking for is a change in your water color. Once the algae is dying your water is going to go from cloudy green to cloudy white/blue. This is normal. Don't use any floc during your shock treatment. You may be able to use it down the road for a quicker cleanup, but we want to make sure the algae is dead first. Let me know how it's working and if you have any questions.
Ken
P.S. I just noticed the posts on CC, and had to add this. The reason I stated that CC is not important in the beginning of shock treatment is the fact that it is a given you will have a high CC reading do to the organic burnout. CC will start dropping once the FC is winning the battle with the algae. Once we get to the point where the algae is mostly dead (cloudy white water), then we can test for CC. Until then , in my opinion, it's a waste of test fluid. Also with TA and CH, you're not going to get an accurate test result with FC at shock levels.
