Results 1 to 9 of 9
Thread: Installing AUTOPILOT SWG.. positioning?
    Mar 2008
    Lees Summit, Mo
    3
    Hi all! New members to forum but have observed as guests for some time. Excellent advice! We are installing an AUTOPILOT SWG. The instructions advise NOT to install unit upside down. We do have some clearance/room issues and wondering if the unit can be installed sideways (vertically) or, alternately, horizontally? Thanks!
    27 x 52 above ground saltwater pool. Hayward S244T sand filter (300 lbs). Hayward SP15932S PowerFlo Matrix 1.5 HP Dual-Speed Above-Ground Swimming Pool Pump. AutoPilot digital (treats up to 60,000 gal). Switched to salt 6 years ago.
    No, you really want the manifold assembly to be in it's standard orientation. The SWG cell produces hydrogen gas and the manifold orientation helps prevent a hydrogen explosion. If it won't fit anywhere on your existing pipe you can always extend the pipe in some direction or another where you have the space and place the manifold there.
    Ft Lauderdale, Florida
    1,462
    Horizontal or vertical is fine. Just not upside down, where the cell is below the manifold in a horizontal direction.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Mar 2008
    Lees Summit, Mo
    3
    Thanks and a follow-up??
    Thanks for the quick responses.
    Sean we have to say your presence here on this forum played a BIG factor in our decision to go with the AUTOPILOT SWG. The installation instructions indicate that the control panel should be protected from the elements. Our panel will have to be mounted outside.. not exactly away from sun, rain, etc.. Any suggestions on some kind of box these things might fit in? Would a cover from a heavy canvas tarp suffice? For that matter, would it be beneficial to shield the manifold with something like canvas?
    Thanks again,
    Rich & Vicki B
    Missouri
    Apr 2008
    SW Florida
    2
    Hi
    You shouldn't have to take any special precautions for mounting outside. In fact it's fairly important that you have an adequate space around your power supply for proper ventilation. Just make sure you're within reach of your cell and trisensor cords and protect against freezing if necessary.
    As I understand it no cover is required when the AutoPilot is mounted against a wall, though having a cover which keeps the rain off is probably a good idea anyway.
    Jul 2007
    Brisbane, Australia
    874
    The way i usually say it to my clients: If you prefer to park your car under cover then it would make sense to make a cover for chlorinator too.
    Mar 2008
    Lees Summit, Mo
    3
    Again.. thanks for the fast and informative feedback. I am an 'over-engineering' kind of guy and so I think I will protect the control box from the elements. The manifold just 'hangs out' there and am still wondering if a canvas-like tarp would be appropriate as a cover as I would like some protection. Any vent issues with a loose covering?
    Jul 2007
    Brisbane, Australia
    874
    Manifold doesn't need cover at all. Power supply might need one because if there is heavy storm water can get through the vent holes. That is if your power supply is in place where rain can get to it.
    Should you choose to cover manifold - anything will be fine, there isn't much heat generated and it's constantly cooled down by water anyway.
