AdrenalinPlease said:21.5ppm fc no cc this morning
jblizzle said:Looks like your CYA is a little on the high side, but probably manageable. Everything else looks good ... except for you FC obviously.
I would recommend starting the shock process, realizing that your shock FC level is 28ppm for a CYA of 70ppm.
Very true, just you do not have measurable CC level does not guarantee clean water. That is why there are 3 criteria in the shocking process. Most likely the CC is being oxidized (by the chlorine and sun) fast enough to not be at a significant level.UnderWaterVanya said:No CC doesn't = No problems; I've seen this myself. It isn't clear why (to me) but you can have Algae and not have CC's.
Not necessarily...it is sort of a personal preference. Our recommendation is if you FC level is below the shock level (for your cya level), and you can see the bottom, it is safe to swim. I also like the CC to be below 0.5 ppm since some forms can cause eye and skin irritation.AdrenalinPlease said:I am assuming there is no swimming while this is all going on correct?
