Thread: Opened last week, here is the store test
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Done with a biogard drop/computer test.
    Note: Bromine pool
    Temp: 60
    TDS: 275 (no idea what this is)
    Sanitizer (br) 1.3
    pH: 7.5
    TA: 85
    CH 125
    According to Jason's caluclator, I need 254oz of baking soda, 195 oz calcium chloride. I turned up the brominator to get the sanitizer #s up and will add some bleach too. Its cold this week, so I will probably do it this weekend. Anything else I should be concerned about? Water is nice and clear.
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    You don't really need either the baking soda or calcium chloride because you have a vinyl pool. The default goal levels are designed for plaster pools. You will be fine with TA between 70 and 90 and don't need to worry about calcium at all.
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Excellent! Thats great news. Thanks Jason. I'll only work on raising the bromine levels.
    Guest
    Do keep an eye on the pH and TA. Bromine is acidic and your pH and TA will drop over time. When it drops to about 60 ppm then you might want to bump it up a bit.
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    ok will do. I test every 3 days or so, mostly out of boredom.
