Thread: Cleaning Intellichlor Cell
    TexasTwister's Avatar
    Feb 2008
    Richmond, Texas
    37
    I have a Pentair Intellichlor IC40 unit that is telling me it needs to be cleaned. Like everything Pentair, you have to buy additional stuff to take care of the problem. In this case, Pentair Intellichlor Acid Cleaning Kit ($27.00 including shipping). This is actually a PVC cap that screws onto one end of the unit and allows you to fill the cell area with a acid/water mixture to dissolve the scale. Without this kit, it seems the only other way to do this is to pour the mixture through the cell over and over again until the blades look cleaner.
    My question is: Is there another way of cleaning the cell blades? Can the cell be removed from the unit and soaked like some other SWGs? I've tried finding PVC parts at Home Depot to screw onto the end of the unit to serve the same purpose as the Pentair kit, but so far it seems that the end of the unit is some odd size so standard PVC plumbing components can't be bought off the shelf. Any help is appreciated.
    15,323 gallon inground pool, Wetedge Primera Stone plaster, Pentair IntelliChlor IC40 SWG, Pentair IntelliFlo 4x160 pump, Pentair Clean & Clear Plus 420 cartridge filter, Pentair EasyTouch control panel, Pentair Kreepy Krauly. No spa, no heater.
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    I think you could probably use a plumbers plug.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    Feb 2008
    Richmond, Texas
    37
    Good thought, but the plumbing "expert" at the local home improvement store didn't think that the plug would be able to handle the 20% muriatic solution for the 30 minute cleaning cycle.
    Thanks anyway. Anyone else have a suggestion?
    Guest
    Bite the bullet and get it. the one for my Goldline unit is $60
    Jul 2007
    Brisbane, Australia
    874
    You don't usually need 30 minutes in 20% acid.
    We don't even recommend using such strong acid to clean cells, we prefer our customers to dilute it to 5-8%.
    I would still try what Sean suggested. If it fails you only losing couple of bucks.
    If you want to go DIY way, you can take a household rubber glove, put it on one end and tie it with a rubber band so it doesn't fall off and then slowly pour acid into it. Just be careful not to spill acid on yourself, if you do - wash it off quickly with large amount of water.
    Ft Lauderdale, Florida
    1,462
    You can also find them in a plastic nut and bold and a rubber stopper.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
