Need help confirming leak test method and diagnosis
steve_h
81
Chesapeake, VA
Hi all,
I noticed a decline in the pool water level and did some research. Checked the obvious. No leaks in the above ground plumbing, pump skimmer gasket, etc. There is no air in the pump skimmer.
I marked the pool level and did a 24 hr pump on/pump off test with all the returns and skimmers open. I had a bucket on the steps for evaporation comparison. The pool lost 5/8" pump on and 3/8" pump off. The evaporation rate was comparable to the pump off test.
This did not really confirm anything, except it leaks more with the pump on.
I plugged up all the skimmers and returns. I marked the pool and bucket and turned the pump off. The water level dropped 3/8" in both the bucket and the pool.
I think this confirms the integrity of the pool. Water drop in pool equals evaporation.
This leave the plumbing! I believe there is a return side leak.
I notice a small amount of bubbles in the returns. AND there is a sunken bit of concrete over one particular return.
The bubbles, coupled with the lack of air in the pump skimmer and the evaporation rate being equal (with the return and skimmers blocked) leads to the return side leak conclusion.
Am I thinking correctly?
Do I have any logic flaws?
Well, a pressure side leak will not generate bubbles. Those bubbles may be from your SWG but they are not from a pressure side leak.
However, a pressure side leak results in water loss, so it is logical to assume your water loss may be occurring on the pressure side.
A pressure leak is usually easy to find because of the visible water but if you have a cracked pipe under the concrete that will be a tough one to detect.
wetchem said:
Can you isolate each return at the pump?
OP probably can't isolate the returns, however, assuming there is more than one return, putting a plug in the suspected return would increase the pressure on that line and, if it's the culprit, the rate of loss would radically increase. In which case the sunken concrete area would be a very good place to cut and dig.
