We have had our Intex 16' x 48" Ultra Frame AGP w/ SWG for about two weeks and are having trouble vacuuming all the dirt off the bottom. We are using a Walmart Summer Escapes pump (1075 gallons per hour) attached to an HTH vacuum head to do the vacuuming, but it seems like it is pushing the dirt around instead of picking it all up. I don't know if the problem is with the vacuum head or with the pump not being strong enough or some combination of the two. If anyone has any recommendations to help get all the fine dirt off the bottom I would really appreciate it. We didn't want to use the vacuum that came with the pool because we didn't want to add water to the pool every time we vacuum. Ideally I would like something that is self-contained that I could just stick in the pool, vacuum up the dirt and then clean the filter without having to hook up this extra pump.
