combined chlorine 1 drop = 0.2 or 0.5 PPM.
Those do not look like the correct instructions or you typed something wrong. If you use 10ml of water, each drop for both the FC and CC is 0.5ppm. If you use 25ml water sample, each drop is 0.2ppm
Chlorine (Free, Combined) Test
1. Rinse and fill large comparator tube to desired mark
with water to be tested.
NOTE: For 1 drop = 0.2 ppm, use 25 mL sample.
For 1 drop = 0.5 ppm, use 10 mL sample.
