Chlorine burn rate?
smuggs
141
Gloucester County, NJ
With a CYA level of approximately 50 in a 28,000 gallon pool, how much chlorine should I expect to burn each day (assuming nothing is consuming the chlorine levels) ? I'm currently running Trichlor but am looking to switch to the Liquidator. Based on some other posts I have read, it seems like 2ppm/day is the estimate I should use. Based on this, I would then expect to need to introduce 116oz/day of 6% bleach. This would then translate to needing to fill the 4 gallon Liquidator every 5 - 6 days or every 9 days if I were to use 12.5% chlorinating liquid. Does this sound right? Based on this, I'm thinking that I may be better off going with the 8 gallon Liquidator....thoughts?
