New pump now lower pressure
Jun 17, 2012
1
I have a 25,000 gl. pool. The 1 HP Hayward Superpump just burnt and I replaced it with a brand new Hayward 1 HP pump. The old pump psi was 30-40 and the new pump psi is less than 10. I can't figure out what could be the problem. There are a couple of leaks that need to be fixed but they were there with the old pump, as well.
Welcome to tfp, pelinkovicci :wave:
What is the model of you new pump? What kind of filter are you using?
30 psi is really high filter pressure, 10 is in a much better range. Are you sure that you gauge is working? Does the gauge go to 0 when you turn off the pump.
What kind of flow are you getting at the pool return?
