Ph staying high
Thanks for the help , One more question is does adding bleach raise ph . I do not have any borate in my pool.should I add borate because I'am using bleach and baking soda but not borate.
My water readings
Ta 60 - 90
Ph 7.5 - 7.8
Cya 60 - 70
Ch 1.5 - 2
Thanks
Let the TA settle around 60 and only raise it back to 60 when it goes below 60.
Bleach doesn't cause any net change in the PH. Adding bleach raises the PH for a short while, and it then goes down again as the chlorine get used up.
If "Ch" is chlorine, your chlorine level is too low. With a SWG, you should keep FC at 3 or higher. Without a SWG it should be 5 or higher.
Thanks yes ch is chlorine . No SWG system just chlorine pool are you sure on have FC at 5 that seam high . That my be why I always have some problem because I always was told not to go above FC 3. Should I use borate or not I have read about it ,some say yes and some say maybe ??
