Pentair platinum psi side pool cleaner not moving?
Steve737
89
Montgomery Texas
Hey guys everything going great with my new pool but..... Now the pool cleaner is not moving. I checked the booster pump its on. I also disconnected the side hose fitting and the screen is clear. Also no water movement in the hole where the fitting attaches. I'm thinking a clog. Any other ideas?
Thanks Steve
Sorry for the late reply. I thought it was cavitating a little due to how loud the pump was. So with that in mind I turned my pool pump up to max rpm and sure enough it primed and started moving normally. I also noticed a small leak at the front of the pump where the PVC attached at the front of the pump. I Resealed it at I haven't had and problems so far. Tanks for the reply. Steve
