Results 1 to 11 of 11
Thread: Doughboy pump filter specs?
    krcossin's Avatar
    Detroit Burbs
    113
    After doing a bunch of good reading here and the other closed forum, I'd like to calculate if I have the correct pump and filter size for my pool. For whatever reason I have been unable to find a website that has the specifications for Doughboy branded Power Pak II 1 horse pump or the Sequel I plus DE filter. I'm sure what I have will work just fine, I just enjoy knowing everything I can especially before I start using it. Any of you pool gods know of such a resource?
    2007 - 24' AG Doughboy Desert Spring dished 1.5', with DB Power Pak II-1hp pump, DB Sequel I Plus DE, Hayward H-Series Heater 100k + 8gal LQ.
    krcossin's Avatar
    Detroit Burbs
    113
    No Doughboy experts out here huh? Oh well, I have what I have and will make due with it.
    Houston, Texas, USA
    148
    I don't believe it. There is someone else in this world besides me that has a Power-Pak II. I have not been able to find out anything either. We have a Doughboy dealer near us. When I called, the guy said he would call back, but never did. I might try that resource again (even though he didn't seem to know what I was talking about). The original installer is out of business. The grids in the original DE filter rotted out, so I replaced it with a sand filter about 2 1/2 years ago.
    Poor Man's Pool
    Doughboy 18 ft round above ground
    7600 gal with center drain
    Pentair sand filter, 1 HP pump
    50 ppm borates
    "I know just enough to be dangerous"
    Pool Calc Ver 1.41 (Excel)
    Ohio
    87
    I don't know if this will help you but they seem to have both the filter and pump listed on their site. They have diagrams of the units and some Manuals for download also;
    Good Luck
    http://doughboy-parts.com/partsmodel.html
    24'x54" Sharkline Matrix by Wilbar International, 15,200 gallons (2015)
    Jacuzzi 75 sq ft Cartridge Filter 1 hp two speed pump
    Solar Heat with Goldline GL-235 Controller
    Intex Krystal Clear Model 28669 SWG
    TF100, SampleSizer, and Speed Stir
    krcossin's Avatar
    Detroit Burbs
    113
    Thanks DrC, I have been there and downloaded the manual, however it does not provide any specifications that I was hoping to get. Other sites that sell competitive branded pumps have all the specifics possible. I just can't understand why Doughboy is so tight with data.
    Houston, Texas, USA
    148
    krcossin,
    Agreed. If I get time this weekend, I'll pop open the pump housing and see if there is a label or anything that might help. I'll let ya know.
    Poor Man's Pool
    50 ppm borates
    Michigan
    11
    Doughboy Dealer
    Having sold Doughboy equipment in my brick and mortar store for 20 years I can say that the equipment you have will be more than enough for a 24' Round Pool. Hope this helps.
    Matthew Austin
    PoolGeek.com
    1-888-354-Geek
    Coupon Code: TFPoolGeek
    Save 10% Any Purchase
    I'm having this same problem, Doughboy does not include flow rates for their filters or pumps, so it's difficult to determine if what you have is paired up properly.
    Houston, Texas, USA
    148
    Quote Originally Posted by Poseidon
    krcossin,
    Sorry it took so long to get around to doing this. Here is all the information that was on the motor itself (other than a warning about proper grounding). Unfortunately I doubt any of this will help.
    GE MOTORS AND INDUSTRIAL SYSTEMS
    AC MOTOR THERMALLY PROTECTED
    MOD 5KH35HN3448FX
    HP 1
    RPM 3450
    A 10.00
    SFA
    AMB 40 C
    TIME RATING CONT
    300-1028
    PUMP DUTY
    Poor Man's Pool
    50 ppm borates
    Re: Doughboy pump filter specs?
    I too have been looking for specs on the Doughboy Pool Power Pak II. Poseidon's specs are correct but Lomart and Magnetek (7-181200-22) also supplied motors for them, the key appears to be the 300-1028 number. My original motor also has a 0-1086-200 number on it. If you're looking for replacement motors as I am then you might want to check out the Electric Motor Warehouse website, http://search.freefind.com/find.html?id ... x=0&I1.y=0 as they seem to have the best prices. I have two of the motors and I just dropped one off at a local company to see if it could be rebuilt and at what cost. The one I dropped off sounds like the bearings/bushings are going out and the other will not restart after it gets hot. Hopefully early next week, they don't work weekends, I will find out about the rebuild and post an update.
    krcossin's Avatar
    Detroit Burbs
    113
    I have had to replace my original pump due to a hose that came off. The dealer gave me a 1.5hp Power Pak ii, however it keeps tripping the 20am circuit breaker. I wonder if I can rebuild the original pump? The motor is quieter, it still will turn, but no water flow. Anyone know if this is possible?
