Type of line for Gas Heater
NullQwerty
342
Hey folks,
I'm putting in a 400k Natural Gas Heater in MA. Gas company is coming in to replace my meter. I've gotten 2 quotes from plumbers for running the line. Both want around 2k for a 70' line. One though is using a flexible line (I'm guessing PE of some kind?), the other is using rigid (guessing coated copper or black steel?). Not sure the exact materials.
What's the preferred material for a natural gas line for a pool heater?
Thanks!
Interesting. I read somewhere though that PE has a problem of critters chewing through it, or getting crushed if you ever have heavy equipment drive over it. Truly an issue, or just internet forums going overboard?
Two issues I had not considered. If the ground was well compacted, I find the crushing a little hard to believe. I suppose there could be gnawing as well. Hopefully someone more knowledgeable will chime in.
You KNOW that the black pipe will eventually rust (also more joints for possible leaks). The PE has no joints except at the end and you MIGHT have crushing/gnawing issues.
Of course 1 member here hit his pool PE gas line with a shovel and put a hole in it ... he probably wishes he had black pipe ... although if it was buried to code more than 3" underground he would not have had a problem. ;)
Exactly why I'm here. It's like asking if I'd rather be punched in the eye or the jaw. My answer is "How about neither?" but apparently that's not an option ;) So, what's worse? Deal with rust and more joints or deal with a more fragile material? I have no idea, they both sound bad, so what's the standard recommendation these days? Thanks
my father in law is retired from Wisconsin Fuel and Light (Gas guy).....anyway I had installed some flex line and when he saw it, he had me rip it all out...and put in black pipe...he said with kids, pets, lawnmowers..you are just asking for trouble with flex line if any of it is exposed, or ever becomes exposed can be punctured fairly easily compared to rigid pipe. The "recommend" for any and all gas installs that rigid pipe be used, period.
The PE will be fine; that's the standard nowadays. As long as it is buried deep enough (18" is code in most areas; check to make sure!) it won't get damaged. Are you going to be driving heavy equipment over it? If so, just bury it deeper or put it inside a rigid conduit where the traffic will be. You can't drive stuff over iron pipe either, by the way! Critters will chew into PE irrigation lines looking for water, but they only do that because irrigation lines almost always leak a little bit and they know there's water nearby. A gas line would be totally dry, so I don't see that happening.
Flyweed, that's assuming the pipe is installed incorrectly (exposed). It should never be exposed; rigid risers should be installed at both ends. I would have no problem with PE.
When people say "flex line" it brings up the thought of the type used to hookup things like stoves and dryers. That is not what should be used outdoors. The "flex" line used for outdoor installations is Polyethylene Pipe. It's yellow in color and is used in underground installations in tons of places. I see it used here all the time by the local municipal gas companies. It's buried 18" underground and is connected with special risers to bring the line above grade. It's save to use and it can be installed in a away that doesn't destroy someones yard. Unlike black pipe where a trench is dug the length of the run. Also, a tracer line is usually installed with it as well so it can be identified before doing any digging.
ps0303 said:
WIt's save to use and it can be installed in a away that doesn't destroy someones yard. Unlike black pipe where a trench is dug the length of the run. Also, a tracer line is usually installed with it as well so it can be identified before doing any digging.
How could it get installed without a trench? I ask because I'm responsible for making the trench in both quotes, so if I could avoid that, I'd love to.
Thanks!
Probably using a ditch witch or something like that .... probably more common to just dig the trench. With the PE and a ditch witch you could install it under a driveway or road without breaking up the surface.
Posted with Tapatalk ... sorry if I sound short ... hate typing on phone :)
So, what do people think about the fact that the price I'm being quoted is the same whether it's PE or Rigid? Without the joints and with the different type of material, I would have guessed that PE would be significantly cheaper. Remember too that in both of these quotes I'm digging the ditch. Is PE just as expensive as rigid or is my PE quote high?
Thanks
Although specialty tools are required to bond the PE to the risers. I would still think it should be cheaper ... get a few more estimates.
A Ditchwitch is a trencher and still digs up the yard. I'm talking about boring a hole through the ground and then pulling the line through it. You would probably have only two holes, one on either end.
As for the cost, the metal risers are not as cheap as one might think. If you are concerned about the cost, ask them if they would do a price break down. Then you could see where the bulk of the cost might be. How did you get stuck digging the trench? Did you or them offer this as a way to cut your costs? Around here the cost to install/bury a gas line will run you $25-$30 per ft. So your $2K cost seems to be inline for where I'm at.
Please keep in mind that a "real" licensed contractor has other costs they include in their price. Their actual profit on a job pays for lots of things such as paperwork, permits, insurance, maybe workers comp insurance and much more. People don't think of this when they get a quote for something. Also, every companies profit margins are different. I've seen the cheapo companies go out of business in a short time because they didn't charge enough and couldn't make a profit. Then people wonder why they are no longer in business when they need them. I see this all the time. I get calls from homeowners that tell me so and so installed this last year but the aren't in business any more. I ask how much they paid and when they tell me how cheap it was, no wonder they aren't in business any more.
Thanks Paul.
Got stuck with the trench cause both places wanted an extra 1k - 1.5K to dig the trench. Neither wanted to do that part so I think they both gave a high number for it knowing that I could do it myself.
I'd love to go with the boring option, but I'd have to do it ahead of time, so I'm not sure how I could maintain the tunnel. Maybe if I put a conduit in. Only thought is that I know the inspectors sometime like to see the trench before it's filled in. I'd have to research that. Also, I could definitely bore a 5' maybe 10' stretch, but a 70' stretch gives me doubt. Don't think I could craft the equipment to do that.
Thanks for the help
bk406 said:
You have to dig the ditch. It needs to be inspected. Pulling a pipe with no trench is basically only done for water irrigation pipe. Thats not a way to install a gas line.
Maybe your area is different but sorry to disagree, I know of several "licensed" gas installers around here that always bore and pull a line. As long as the two ends are left open for inspection. I guess you've never seen it done and that's why you're not sure. Even large contracting cable companies pull lines like this. Gas or not, it's an acceptable way in most areas. People don't like their yards destroyed by digging.
Thats for boring a hole for a line under a road or driveway. I've seen that done many times. Thats completely different than just pulling a gas line 100 feet across someones yard like installing irrigation line. Gas lines have to be at least 18 inches below grade, and a detection line has to be put in the ditch so the gas company or dig safe can find it again. You couldnt get a permit to do it any other way here except a trench. The OP and I are from Massachusetts. You florida guys can do darn near anything and get away with it. Up in yankee country, they still use copper shower pans :hammer:
Even on the front of the website you linked to, they have dug a trench in the yard before boring the hole under the drive.
