Hayward de4800 relief valve not tightning
May 21, 2009
32
I have a de4800 my issue is the relief valve is leaking. The threads on the tank must be stripped I have already tried a new relief valve but it just does not tighten. I Tried wrapping the threads on the relief valve with teflon tape but still can't get it to seal any advice on what i can do. There must be something i can do i really dont want to replace the tank.
Do you guys think a thru hull fitting or bulkhead fitting may work i have seen them with threads on the inside hole too but the smallest i have seen is 1/2 inch but for half inch to fit i will have to make the hole bigger. It would be nice to find a 3/8 double threaded bulkhead adapter any ideas if this will work.
Sent from my Transformer TF101 using Tapatalk 2
