Results 1 to 10 of 10
Thread: Use sodium bromide with SWG?
    Hi all,
    I just picked up a (slightly used) Polaris AutoClear Plus SWG which I'm installing this weekend and I just found this site, I think it's going to be a great source. I already have a question (of course):
    In the SWG owners manual it has a paragraph that states:
    "When sodium bromide is used, it is in addition to the required sodium chloride levels. Refer to the sodium bromide requirements chart in the Reference section."
    And it has a table showing how much sodium bromide to add. But nowhere in it does it say that I MUST use sodium bromide or what it's for. I've not seen anything about sodium bromide before in the reading I've done about SWGs. Is this something I must or should add? What's it for?
    FYI, I'm in the Phoenix area (hot), and have a 30,000 gallon in-ground fiberglass pool with a 36sqft DE filter and 1hp pump.
    Thanks.
    John
    John
    Tempe, AZ
    Don't add sodium bromide. You would only use sodium bromide if you were using bromine as a sanitizer instead of chlorine. Bromine is fairly commonly used in hot tubs but hardly ever used in pools. Bromine is not suitable for an outdoor pool in any case.
    They are just listing it to be through and cover the occasional person who is using bromine in their indoor pool.
    Guest
    Also to let you know that their unit CAN be used in a bromine based system. Not all SWGs can. It is an option for indoor pools, basically but not very useful for outdoor pools.
    Ft Lauderdale, Florida
    1,462
    First you have to add the correct amount of sodium chloride (salt) then whatever their chart says for sodium bromide (bromine salt). Most of the time this is not available in bulk quantities. However, you can find it as Yellow or Mustard Algaecides. It's the main ingredient.
    With a SCG, it is not necessary because (IMO) all the qualities of a SCG gives you the benefits of an indoor bromine pool/spa. You'll end up spending more money to maintain a bromine pool/spa because if your pool/spa is outdoor, there is no stabilizer for bromine, AND the cost of sodium bromide is in addition to the sodium chloride.
    I suggest to just leave it as a chlorine generator and not worry about the sodium bromide. It's only an option.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Thanks
    Thanks for the responses. I wanted to be sure I wasn't missing something and I sounds like I'm in good shape. It's all wired up; I'll get it plumbed in today. (I'm using this opportunity to remove about four full u-turns from my plumbing flow too.) Then I've got about 7-800 pounds of salt to add.
    Thanks Again,
    John
    John
    Tempe, AZ
    billyjoeraybob's Avatar
    Apr 2008
    SC Midlands
    50
    John,
    Just a word to the wise. Be sure to test your water for existing salt prior to adding that 7-800 lbs. I was surprised to find my water tested at 1500 ppm before I put my first bag of salt in the pool.
    Good luck,
    Bill
    Bill
    18' x 36' Freeform IG Gunite with 7' spa, Super Blue DiamondBrite, Pentair 1.5 hp circulation pump, Pentair 2.0 hp spa booster pump, Pentair Triton II Sand filter, Polaris 280 with booster pump, Pentair Intellichlor IC40 SWCG, Jandy Laars LX 250k btu NG heater, TF-100 test kit from http://www.tftestkits.com/
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    You won't find many people around here recommending test strips, but THIS ONE is pretty accurate for testing salt. You'll want to be able to verify your SWCG on ocassion.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    John... How do you like your Autoclear Plus?
    So now that your Autoclear Plus has been running for about a week now... How do you like it so far? Any issues with installation/startup?
    I just picked up the Polaris Autoclear Plus for my 26Kgal IG. I looked at the other brands and settled on the Polaris for these reasons:
    • Cost: $734 delivered for a new unit. Replacement Cells are $365 delivered.
      Cell Size/Installation: Compact cell that can be installed vertically or horizontally and only requires a 22" straight run.
      Brand/Name: It's not a pool pilot or Hayward(Goldline), but I figured that Polaris is a rather safe bet (lots of polaris dealers around here).
    I am a bit nervous since the Autoclear Plus is not one of the more popular units. I just couldn't resist the price.
    26Kgal IG Vinyl liner
    Hayward 1HP Superpump
    Hayward Pro Grid 4800 DE Filter
    thepoolcleaner pressure side cleaner
    Quote Originally Posted by billyjoeraybob
    John,
    Good luck,
    Bill
    Thanks Bill,
    I only wish I'd seen this sooner because now I have too much salt in my pool. See my latest question here: http://www.troublefreepool.com/viewtopic.php?t=4773
    Whoops,
    John
    John
    Tempe, AZ
    Re: John... How do you like your Autoclear Plus?
    Quote Originally Posted by eelhc
    eelhc,
    It hasn't actually been up and running for a week yet becasue I ran into a little plumbing snag that delayed me a few days while I got a couple of new PVC fittings and found the time after work to get it all put together.
    Anyway, it's been running about 3-days now and so far I couldn't be happier (other than the fact that I over-slated my pool). The unit fired right up, sensed the flow, told me my salt level (ugh), told me its output amperage and voltage and, judging by the chlorine levels, is making chlorine just fine.
    Unless your's is much different from mine I don't see why you would need a 22" straight run for the cell. My cell is just over 10" long.
    Installation was a piece of cake. I tapped into the power supply to the pump (from the timer). Wiring was simple (especially with 220v). I screwed the control unit to the block wall of the pump house and plugged the cell cable into the contoller.
    Good luck,
    John
    Good luck,
    John
    John
    Tempe, AZ
