Thread: cya with the talyor k-2006
    Ohio
    217
    Hi all I'm working with the cyanuric acid test and it has 2 scales on the back of the tube one is cya and the other is ml i get 50 cya and the ml is about 5 what is this ml scale for? i'm starting to feel real stupid at this point because I bought strips and they indicate below 1 ppm cya I think I'm reading the tayler kit wrong. what would i be doing wrong. Taler says read comparator tube at liquid level on the back and record reading as parts pr million as i did and get 50 but checking whith strips i get less then 10 over and over. I'm not saying the strips are right but I realy think I'm missing somthing. signed Duuu
    Ric W
    My Pool
    8605 gal fiberglass, 3/4 hp pump, sand filter, aquabot cleaner, heat siphon heat pump, tiger river(sumatran) spa
    RAA's Avatar
    Mar 2007
    The Woodlands, TX
    46
    Re: cya with the talyor k-2006
    Quote Originally Posted by ric
    ml = Milliliter.
    You can run two test on that same tube. When you test for chlorine, you fill the tube to 9ml (milliliter) and then perform the test. Its just the amount or water needed to perform the CL test.
    When you test for CYA, you use the plain numbers in the back to read the PPM of CYA. So if you are testing for CYA and the black dot is no longer visitble at 50, that means your CYA is at 50PPM.
    -Rick
    ~15k Gal IG
    Gunite/White plaster
    AquaLogic PS-8 w/SWG
    Ohio
    217
    Thank you so much for the help RAA great information I just had to be reassured. Now I can try the 9 ml test. I overlooked that somehow.
    Thanks Again
    Ric W
    My Pool
    Guest
    The color comparator block in your kit is basically the same one used in the K-2005 which has a different test for chlorine and uses a color comparator. The ml markings are used with this test. You can disregard them.
