CSI question
Miscanthus
71
I am confused about the CFI numbers on the pool calculator.
My pool: 20,000 gal. Intellichlor Salt Generator Plaster surface (new plaster 3 weeks old)
FC 5
pH 7.5
TA 120
CH 340
CYA 70
Salt 3400
The CSI number on the left is -0.28 and reads "balanced"
The CSI number on the right is -0.32 and reads "potential for corrosion"
Why is there two numbers?
Thanks
The number on the left is a calculation that corresponds to the now column (left most) measurements you put in for the test parameters (pH, TA, CH, CYA, Temp, Salt level, Borate level). The number on the right is a calculation that corresponds to the Target column (right most) of where you are adjusting those parameters to.
There are two columns, "Now" and "Goal". The number on the left shows the CSI for the "Now" column, while the number on the right shows the CSI for the values in the Goal column.
With plaster only three weeks old, you shouldn't be worrying about CSI just yet. The TA and CH levels will continue going up as the plaster cures. If you adjust them now they will probably end up being too high in a couple of weeks.
If I adjust to the number on the right then the reading "potential to become corrosive". How do I know what number to adjust to?
Thanks for the response.
At what point should I start adjusting for CSI? How old should the plaster be?
Thanks Jason
