leaks in 24 foot round pool
briand
10
Does anyone have experience with fix a leak? I have small pinhole leaks down at the transition part of the liner where the walls of the pool transition to the bottom of the pool, I get small pinholes in this part of the liner anyone know what causes these small leaks, I can patch them but the next year there's always more to find. I'm going to try fix a leak to see if it helps, i read that it is kinda of a last resort but the only other alternative is a new liner,
How old is the liner? If brittle and old it will eventually fail. I found this out the hard way with mine in the winter when it let go and froze. Destroyed the walls so a tottal replacement was needed. But the pool was 30 years old so it eventually would have needed it.
