Results 1 to 8 of 8
Thread: Pump problems
    Jun 2007
    New Orleans
    111
    Pump problems
    I have a Aquatools 2speed 2hp pump(2 months old) plugged into a gfci. When I got home yesterday, the gfci wasn't tripped, the pump was on low speed, but wasn't working or making any noise. I reset the gfci, unplugged the pump, plugged back in, and turned the pump back to low speed. The pump would make noise but the motor wouldn't turn. Does anyone have any ideas? Is this pump bad or is it stuck?
    Thanks
    21' Round AGP, 10k gallons - 2hp 2spd pump - 300lb sand filter - Stenner Chlorine Injector - Pool Rover
    it sounds like its jammed up
    can you turn the impeller?
    Try opening up the pump strainer basket area, removing the basket and looking to see if there is any debris under there. For most pumps that will also give you access to the impeller, so you can check to see if it turns freely as all your parts suggested.
    Jun 2007
    New Orleans
    111
    I tried turning the impeller from the outside of the pump and it turns. Should it spin when I turn it or should it turn the amount I turn it, only? I also took out the strainer basket and turned the impeller from the inside. It turns but only the amount that I turn it. I turned the power on and still nothing. I contacted the store I bought it from and they said they will probably swap it out for a new one.
    Mar 2008
    Maryland
    56
    Well, the impeller and shaft should spin as much as you turn it. It wont spin freely. However, if you are feeling alot of resistance or a grinding then the impeller is probably clogged. Often, if a pump isnt used for a few months, the shaft will lock up. Usually spinning the shaft first will fix this. There is a chance the pump is not wired correctly or there is an internal problem with a motor component. I'd say swap out the pump or motor-however- if it is not wired correctly then the store or service company may not accept another return.
    Jun 2007
    New Orleans
    111
    The impeller will spin as much as I spin it. I don't think there is much resistance. The pump and filter were installed by an installer that works with the company I bought everything from, so I'm pretty sure they will take care of the pump. The pump is brand new and has only been used for two months.
    it sounds like you have done everything you could im sure they will just swap it out and you can get on with your pool season
    Jun 2007
    New Orleans
    111
    The start capacitor was bad on my pump. Changed it out and everything works fine.
    Thanks for everyone's help.
