Cant find it in your thread....what was it before it went to zero?CYA went to 0
Yep, I'm with ohm_boy. I'd be careful about putting more in there....it is not easy to get out.Funny stuff, that CYA. It doesn't normally go away.
I would immediately distrust the test.
You may not be getting the gist of how shocking works. Applying chlorine and walking away isn't shocking. Shocking involves attaining shock level for your CYA and *HOLDING* it there consistently until there is no overnight loss, CC<1, and the water is clear. If you allow the FC to drop during this time, you allow algae to multiply (which it does by doubling, so it takes virtually NO time to bloom big). This is a process, and it ain't done until it is done.Couple more shocks should do it, I hope..
Johnny-M said:It makes me sick to think I have to redo the shocking process.
