So - first time pool owner. Opened a few weeks ago to clear water but a 110 CYA which would be impossible to maintain. Removed all pucks a week or so ago and will be doing BBB.
Replaced about 20" of water this weekend, ad started up the pump this am. After 2 hours of pump time, here are my results
FC - 7
CC - .5
CYA 60
TA - 90
temp 59
Didn't run CH, had to get to work and was already late.
Water is clear, but a bit dirty from water drain/refill process over the weekend. Will vacuum tonight.
The pool calc says add borax, which I'll do tonight as well. Anything else I should do?
Would ultimately like to install a SWG in ye next 30 days. Should I leave CYA at 60?
TIA,
Brian
FC - 7
CC - .5
CYA 60
TA - 90
temp 59
TIA,
Brian
