Thread: SWG - AutoPilot Start Up Temperature
    Mar 2008
    Pelham Alabama (Birmingham)
    69
    Yes, me again. Thanks for all of the help. Just a very quick question.
    With my new Auto Pilot SWG, I have read there is a temperature where the unit is the most effective, and there is a temperature where the unit is totally ineffective.
    What should the water temperature on before turning on the Auto Pilot SWG? I guess that would be the same temperature the unit should be turned off in the fall?
    Mister Mister
    IG 18 x 36 Vinyl
    30,000 Gallons
    AutoPilot SWG
    Aquabot T2
    Hayward S244 Sand Filter
    Hayward 1hp RS1000 Pump
    Leisure Bay Spa - Flores - 500 Gallons
    AutoPilot SpaPilot - Not Yet Installed
    Ft Lauderdale, Florida
    1,462
    hey Mister x2
    The AutoPilot will work at any temperature. However, the automatic temperture compensation feature will automatically adjust the Purifier Outout % higher (as it gets warmer) or lower (as it gets colder), based upon water temperature fluctuations.
    As it gets colder, the adjustment will drop down until it gets to 55 degrees, at which point it will limit the output to 1% maximum, to aovid overchlorination. At the same time, it does not shut down under cold water conditions.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    The AutoPilot has temperature compensation so it doesn't hurt to leave it on at cold temperatures, as long as it is above freezing. However, below about 55 degrees it won't be doing very much. I turn mine off around below 55 and switch to bleach.
    Mar 2008
    69
    Great, thanks fellas,
    So I have no concern with the temp. I'm however waiting to turn it on, need to clear the green stuff, and replace half or a little more of the water (in the am) to correct my CYA issue. And yes, I also need to get and add the salt.
    Someone did tell me somewhere along the way to not assume the pool was at 0 ppm of salt. GREAT advice, I show the water at I believe 500 or 700 or something, which does have bearing on what to add. With my 30000 gal pool, I'll probably dump 10 or so bags and measure from there.
    IG 18 x 36 Vinyl
    30,000 Gallons
    AutoPilot SWG
    Aquabot T2
