Which levels to use
esdd
Feb 12, 2012
35
Greenville Indiana
I am setting my pool up as a swg pool but I will be dosing bleach or pool store lquid chlorine untill the swg is purchased in early fall or next years opening. Right now I have about 3200ppm salt in, and the boric acid is on the way. Cya is at 50, fc 4.5, ph 7.3, ta 210, ch 210. My tap water is even worse! I found threads reccomending using the swg levels, and others to use the fresh water list. Right now the salt and boric acid is mainly to improve feel.
TIA Eric
