brg88tx
0
i've read somewhere on here that sodium hypochlorite (bleach) slowly oxidizes cya. i believe this is true. i lose 5-10 ppm of cya per month when i'm using only bleach to chlorinate.
chem geek said:4 tabs in 15,000 gallons would be around 9 ppm CYA so yes, something is amiss. The test doesn't read well below 20 ppm and your test doesn't read below 30 ppm so when you said 0 it could have been just less than 30 ppm. Was the water in the tube crystal clear in seeing the black dot or did it have some cloudiness when filled up to the top?
The CYA test is sensitive to lighting conditions. The best approach is to have the sun to your back and hold the tube in front of you blocking the sun and look straight down. This is strong indirect light which is how the test was effectively calibrated.
So maybe you had 20 ppm so could still see the black dot at 30 ppm, then added 9 ppm to now have 29 ppm, and are looking under different lighting that has this 30 look more like 55-60. Still, that's further off than I'd expect even with such errors.
You should upgrade your test kit to the TFTestkits TF-100 or the Taylor K-2006, both available at the same tftestkits.net website. It has a better Taylor CYA test that measures down to 20 ppm.
Isaac-1 said:Was the initial sample taken from at least a foot below surface level, I am not sure of the condition of your pool before the sample was taken, but if there was no circulation and the pool water was cold, and if there had been any significant recent water addition either rain or manually, that warmer fresh CYA free water could be floating on top of the CYA filled pool water.
FarmerJohn said:chem geek said:4 tabs in 15,000 gallons would be around 9 ppm CYA so yes, something is amiss. The test doesn't read well below 20 ppm and your test doesn't read below 30 ppm so when you said 0 it could have been just less than 30 ppm. Was the water in the tube crystal clear in seeing the black dot or did it have some cloudiness when filled up to the top?
My initial 0 ppm test was as if the tube was empty - no turbidity visible at all. All tests' lighting conditions were done pretty much as you described. Since my background includes several years of manufacturing engineering working with chemicals and using visual criteria I'm aware of the hazards of haphazard test methods. With that in mind I wasn't sure what the temperature was for the first test (per Bama's comment) so I took a sample this morning and stuck it in the fridge to chill it well below 70F.
To push the test to total sloppy method I just squirted in the reagent, didn't mix it and started filling the sight tube.
I need a drum roll.................this poorly mixed and chilled sample measured 90 ppm. The test reagent is the same I've used for all 4 tests. :?:
I didn't get by the pool stores yesterday with a water sample but that will happen today. At this point I think I'll monitor things for several days and see when/if levels settle out.
