Thread: Hayward valve SP0704DE - leaks
    I have the above valve in my system. It is leaking around the gasket between the top and bottom halves of the valve, and it is difficult to turn the handle (I do push the handle all the way down before turning it). I've seen a part "key, cover and handle assembly", part number SPX740BA on a number of web-sites, and it has been suggested that I install this part.
    Is it as easy as removing the cover screws, dropping in the part, and re-installing the screws ? Do I need any kind of sealant for the gasket ? Thanks in advance for any help.
    In-ground, free form, 18' x 38', with attached 7 ft diameter oval spa. Gunite with Durazzo plaster. Startup - September 2006.
    20,000+ gallons, 8.5' deep end with diving board. 2 skimmers, MPI autofill.
    Hayward Northstar 2.5 hp filter pump, Super II 1.5 HP for weeping wall and water fall.
    Polaris 280 cleaner with booster pump. Hayward DE filter (DE7220). Hayward H series 400,000 BTU heater.
    Aqua Logic PS-8 control panel, Turbo Cell chlorinator, wired spa remote, wireless table-top remote.
    (2) QT blowers for spa.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Hayward valve SP0704DE - leaks
    Quote Originally Posted by tfreejp
    The changeout is simple, all you should need is a #3 phillips head screwdriver (the nuts are 'lock nuts' so you don't need a wrench to back them up). I would use some silicone or teflon based lube on the o-ring!
    I've gotta admit I'm a little confused on your multiport# I've got a copy of the 2006 parts guide here and the SP0704 looks like it's for sand filters. I'd definately double check the part # before ordering one (sand filter multiports have all the functions [backwash, filter, etc] 180 degrees opposite of DE multiports - this is because sand filters are top fed and DE filters are fed from the bottom) If your multiport is 'side mounted' (which I think it is) the 0704 is going to be backwards. DE multiport numbers run something like SP07##XR##... The "R" designates that it is for DE filters (it's 'R'eversed from the sand orientation).
    I hope that this will enable you to get the right part to fix the problem
    Luv& Luk
    -Ted
    Thanks for the input.
    I went back out to look at the valve. The model number on top is actually SP740DE. The filter is Pro-Grid DE7220.
