- Feb 19, 2012
- 78
mas985 said:I am not sure I understand what you are describing.peachy said:RETURN: six 1.5" and two 1.5" of jets. every two returns (each with gate valve) are paired together.... and paired again.
SUCTION: two 2" main drains and three 2" vacuum.
Does this mean you have 8 separate return lines going from the equipment pad to the pool and 5 separate suction lines going from the pad to the pool? Also, why do you have three vacuum lines?
hi mass,
yeah i think that's how it was designed. do you see a problem to it? to be honest i don't know what that vacuum is but it's on the suction line and all the 5 suction lines has a gate valve.
