cliff_s said:Note: ALL O-Rings large and small need a coating of silicon lube(Magic Lube or etc)
when installed. The reason the O-Ring must move very slightly to provide a good seal,
without lube it sticks and won't fill the small holes and then it leaks.
If the O-Ring isn't damaged it probably does not need replacing, a good coat of
lube should make it seal.
Cliff s
Thanks, Cliff. We hope to be able to check it out out this week.
Joyce
