Hayward Ecostar and Goldine Pro-Logic Wiring
Oct 23, 2008
90
Bonita Springs, Florida
Hayward Aqua Rite (T-15)
I have a Hayward Ecostar VS pump that is controlled with a Goldline Pro-Logic using the communication interface. I read in a post on this forum that the pump should be wired directly to the breaker and not wired to the Pro-Logic pump relay:
1. I'd like to know if wiring directly to the breaker instead of the Pro-Logic relay is correct;
2. If I bypass the Pro-Logic relay, then does the communication interface detect low/no flow to the pump and it would shutoff the pump?
Thanx
Rick
1. Ok, I did read that but I didn't know if page 9 was for a stand alone application without using a Goldline Pro-Logic controller. Sometimes when they write the manuals they are just specific to that product and don't take into consideration other installation options;
2. Again, if the pump is being controlled by the Goldline Pro-Logic controller with the communication cable, does that supersede the controller on the pump. I know that the pump speeds on the pump are locked out when using the Goldline Pro-Logic controller with the communication cable.
1. It is a direct connection as shown here: http://www.hayward-pool.com/pdf/manuals ... gement.pdf
2. The ProLogic interface cable connection only disables certain features but not the error detection in the pump controller and none of the safety features (SVRS). The connection allows you to program the pump from the ProLogic but it also reports the errors generated by the pump drive. So if there is any error in the pump, it should be displayed on the ProLogic display.
