WhoDat? said:
They say to add another suction line in the side of the pool if you get rid of the drain.... What's that all about? That seems more dangerous to have a suction in the side wall rather than all the way at the bottom.... And also some say it messes with the pump if you don't have a main drain..... I'm leaning to the no main drain side, but I just want to be sure before I skip it!
That is for the rare situation where the water level might drop below the skimmer and to protect the pump they will plumb a suction line below the skimmer at a lower depth into the second port of the skimmer. A valve is used so that this suction line is normally closed but when the level of the water drops, a float in the skimmer seals the skimmer path and then the valve in the bottom of the skimmer releases so that water can be drawn in from the lower point. This isn't really needed if you have an autofill but some people like the idea of extra protection. As for safety, it can be plumbed fairly low and out of the way and they use the anti-entrapment covers and can also be plumbed into pair so that shouldn't be an issue. Plus, they aren't normally activated unless you want that. The following link shows how this is usually plumbed:
Skimmer Equalizer
I don't remember if I posted this link before, but the APSP did a case study on main drains and came to the conclusion, that they were not really necessary:
APSP Case Study
Pool and Spa News Article
Also, here is a video showing how a 18"x18" main drain running at 800 GPM hardly moves the water. This is equivalent to a main drain pair running at 34 GPM.
Main Drain Video
