Results 1 to 9 of 9
Thread: Borates measure the same after almost a year?
    Carrollton, TX
    126
    Ever since I put borax in the pool last spring to 50ppm using the test strips as a guide, it has stayed at that level and after testing yesterday, it is still 50ppm even with all the rain we have had and all the backwashing and refilling I have done in a year's time. It is hard for me to believe this as I have had to add salt and CYA over time as pool water is lost down the overflow drain and from backwashing. Plus I still have a thriving colony of waterboatmen in the water.
    I have to assume the Aquacheck strips are not reading correctly. Even testing tap water it shows 50ppm. Expiration on bottle says March of 2009 and bottle has been indoors and cap on tight. Is there another brand out there that may be more accurate?
    7000 gallon IG freeform w/ 6 ft. spa, 21 ft weeping wall, Hayward SP4020NS Northstar pump, Colorlogic LED’s, DE6020 filter and H400IDL2 400,000btu heater. Aqua logic 8 zone controller with Aqua Rite salt chlorine generator, Stonescapes pebble finish – Aqua Blue and flagstone coping, stamped/stained concrete deck
    Guest
    I have experienced the same problem with the Aquachek strips. I am guessing that humidity is the culprit. I have has MUCH better results with the LaMotte borate strips and they are much easier to read also. The color changes are much more distinct!!!! I have gone through several bottles of the Aquachek strips and EVERY one did what you describe after several months so once they are opened they do not have a long shelf life. I have not had the same problem with the LaMotte strips.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Evan, would keeping them in the fridge help prevent the problem, and if so - would the strips need time to get to air temp before using them?
    Luv& Luk
    -Ted
    Carrollton, TX
    126
    Thanks waterbear. I will google and find somewhere to order LaMotte online.
    Guest
    Quote Originally Posted by waste
    Don't know. I've given up on them and switched to the LaMotte ones!
    Guest
    Quote Originally Posted by txborn
    I've ordered from here.
    Feb 2008
    Dripping Springs, TX
    79
    Yeah, I too just ordered the LaMotte Borate strips from Lambert.. It shipped yesterday!!!
    gonefishin's Avatar
    Joliet, Il.
    413
    I haven't used my Aquacheck Borate strips yet this year, but they seemed to offer believable results. During a summer with near record rainfall I did notice a substantial drop in my borate level leading me to add more to bring my levels up to 50. But I'll certainly keep this in mind if the numbers appear suspicious.
    dan
    33' Aqua-Leader AGP
    Hayward cartridge filter and IntelliFlo VS pump.
    Solar Heat coming ; used to own Aqua-Cal HeatWave 100k (HeatPump)
    Aqua-Rite t-15 SWG
    Guest
    Easty way to check them. Use plain tap water. Good strips will have a purple color. Ones that have gone bad will stay tan.
