Results 1 to 15 of 15
Thread: Improvements to Pool Calculator
    For the next few days I am beta testing some improvements to my Pool Calculator. You can access the beta test version at Pool Calculator.
    The Pool Calculator now remembers it's configuration. Units, pool size, goals, etc are all saved between sessions.
    It is now easier to work with spas and very small pools. Small numbers of oz are now shown to the nearest tenth of an oz and if you mouse over a volume it will now show teaspoons in the info bar when appropriate.
    The amounts of chemicals recommended to change the PH now take the current PH and TA levels into account. The calculation is still approximate and doesn't take other factors that might affect the quantities required into account, but in general it is now far more accurate than it was before.
    This is a beta test version, as such not everything may work correctly and amounts of chemicals or other calculations might be wrong. Because of that I am leaving the old version up at the normal URL for the next few days. When this version has gotten more testing I will replace the previous version with the new one at the normal URL.
    I welcome any testing, feedback, questions, or comments you may have!
    Thanks
    Jason
    I have high CH (540) and I need to refill, my tap water has 120 CH. I did not see where I can find out how much my CH will drop if I drain x amout of water.
    Is this something that can be added to the Calculator?
    20x40 24,000 gal IG plaster/CircuPool RJ45 SWG/2 skimmer/2sp 2.5hp Jandy Stealth/340sq ft cart filter/600sqftHeliocol Solar Panels/6ft semi circlr tanning ledge/25ft deep end bench/5ft sheer descent/2 lion head water features/1300sqft travertine paver/2 Colorlogic lights/Hayward Navigator/3step 2ft raised bond beam
    Mesa, AZ
    16
    Just an observation, if I put in a combination of 500 gallons and 12.5% bleach, it tells me to add 1 oz to go from 3 to 7 ppm. If I put in 12% it tells me 2.1 oz, if I put in 13% it tells me 1.9 oz. If I switch it to 5000 gallons and keep 12.5% it says 20 oz. The 1 oz. recommendation seems out of line with the others. I'm not sure why I stumbled upon that on my 1st try, but just FYI it seems a little odd.
    Chris W
    My Pool: 14K gal IG, Pebblesheen, Pentair 420 Cart Filter, Autopilot Digital SWCG, Paramount PV3 In-floor cleaning. UltraPure Ozone
    My Spa: 2007 Down East Windsor SE, Spa-Pilot SWCG :)
    My Kit: PS-234 w/salt test, Refills from Taylor and TFkits
    Quote Originally Posted by cwstnsko
    Thanks! Fixed now.
    It was rounding the part to the left of the decimal point down and the part to the right of the decimal point up. It now shows the correct answer of 2.0, instead of 1.0.
    Quote Originally Posted by JCJR
    Good point. Right now it can tell you what to do if your fill water has no CH, but there is no way to figure it out if there is calcium in your fill water. It would also be nice to have the calculation run the other way, right now it shows % to replace, but it should also tell you what happens if your replace X%. I will add both of those to the wish list for a future version.
    Mar 2007
    San Rafael, CA USA
    12,082
    And you can add an option for one-time partial drain/refill dilution, which is the sort of calculation described in the posts above, or a continuous dilution which is computed by the formulas below:
    Dilution % = 100% * ( 1 - EXP(-(Volume % / 100%)) )
    Volume % = -100% * LN(1 - (Dilution % / 100%))
    So replacing 100% of the water volume through continuous dilution results in dilution of around 63% (more than half diluted) so equivalent to draining 63% of the water and refilling. I'm defining Dilution % such that 100% would be a complete dilution or drain/refill.
    Richard
    Jun 2007
    Hunterdon County New Jersey
    19
    I was playing on the beta pool calc, I set my pool volume to 13000 gal. All other items set to 0, except PH:
    Set the "Now PH" to 6.8 and Goal to 7.4. This gave me a recommendation of 16oz by volume of borax. When I set the Goal to 8.8, it gave me the same result. Possible bug?
    JasonM
    15x30 AGP built myself in 2008: 3/4 hp 2-speed Waterway Supreme. 300 lb Pentair sand filter. 160 SqFT solar.
    Quote Originally Posted by Jason
    Well, yes and no. The answer is wrong obviously, but that is the behavior I expect. The issue is in the way I estimate quantities for large PH changes. PH changes are very non-linear and I have a much simplified model that makes mistakes for large PH changes in general and for changes that go from well below a PH of 8 to well above a PH of 8 in particular. The error is also compounded because I don't handle TA near zero very well either.
    Still, the results are much closer than they are using the previous version, which gave 69 & 228, when more accurate numbers would actually be around 8 & 73. Modeling PH changes is very difficult. The new approximation is better, but it is still far from perfect.
    Feb 2008
    Miami, FL
    38
    I ran a test with my CYA level of 55 against the Chemgeek Chlorine / CYA chart and the results didn't return what I expected.
    Poolcalc
    CYA 55
    Normal 3-6
    Shock 15
    Mustard Algae Shock 24
    (the previous non-beta calc gave 4,9,17,32 as the corresponding values)
    Chemgeek CYA chart (approximate values based on average of 50 and 60)
    Min FC 4.05
    Target FC 6.25
    Yel/Mstrd Min 8.25
    Shock FC 21.75
    Yel/Mstrd Shock 32.15
    Chemgeek approximations
    "Min FC" is 7.5% of the CYA level = 4.125
    "Target FC" is 11.5% of the CYA level = 6.325
    "Yel/Mstrd Min" is 15% of the CYA level = 8.25
    "Shock FC" is 40% of the CYA level = 22
    "Yel/MstrdShock" is 60% of the CYA level.
    18,000 gallon 17 x 35 in-ground diamond brite, Fafco solar, SWG, Barracuda G3, well pump - Biscayne Aquifer CH=250
    You probably forgot to tab to the next field or press the calculate button. The numbers don't update till you do one of those. The Suggested FC Level calculation is the same as it was before, 4, 9, 17, 32. The remaining differences from Chem Geeks numbers are intentional. I have a slightly different interpretation of shock levels based on a slightly different interpretation of Ben's Best Guess chart.
    Thanks to everyone who had a chance to try out the beta version.
    I have moved the new features (remembering settings across sessions, more precision for small values, and improved PH calculations) into the regular version, available as always from http://www.poolcalculator..com/.
    matj6876's Avatar
    Jul 2007
    DFW, TX
    105
    Jason
    I've been using poolcalc since last summer. You mention above that you have made changes to the Ph caculation.
    My numbers today for my 15000 gal pool are:
    FC 8.0
    CC <0.5
    pH 8.0
    CH 480
    TA 80
    CYA 60
    B 50
    Na 3800
    Temp 60F
    At this stage I would usually add muriatic acid to take the pH down to 7.6.
    I'm constantly battling rising pH so this is nothing new.
    I would expect to add between 24 & 32 oz, as directed by poolcalc.
    Right now it is telling me to add 12oz. Under half what it used to say.
    Could you offer any advice?
    My Pool: 27K gal IG plaster, IntelliFlo i1 pump, Pentair FNS Plus DE Filter, Intellichlor IC40 SWCG, Polaris 3900 Pressure Side Cleaner
    PH calculations are complex. The new approximation is still an approximation, better in many cases than the old one, but not in your situation. The old calculation depended only on the starting end ending PH. The new one takes into account the starting TA. However, borates, salt, CH, CYA, and temperature also factor into the true value.
    Assuming B 50 means borates are at 50, using a more exact calculation with your numbers I get 23 oz to go from PH 8 to PH 7.6. The borates make a large difference, as does the temperature. If your borates were zero it would be 9 oz. If the water was 90 degrees it could be more than double those amounts.
    Because PH changes depend on so many different factors it is commonly impractical to calculate an exact amount. The Pool Calculator can provide a good starting point but you will always need to test after any addition and adjust as needed. With experience you get a feel for how your particular pool responds and can make better approximations.
    Mar 2007
    San Rafael, CA USA
    12,082
    If you're a masochist, you can use the Pool Equations spreadsheet I wrote for more precise calculations, but it is not designed for novices. It looks like I really should spend some time creating a simplified model Jason can use for his online calculator, but I just don't have that sort of time right now (it's complicated to do).
    Richard
    matj6876's Avatar
    Jul 2007
    DFW, TX
    105
    Jason - Thanks makes sense. Yes B 50 was my way of saying 50ppm of Borates, did not know what the correct abbreviation was. Before I saw your post I added 24 oz of acid and retested. pH went down to 7.6 so you are spot on with your math there as far as I am concerned!
    Richard - Wow! Just downloaded the sheet. That's going to have to wait til I get back from the next business trip but I'm up for a bit of masochism - looks like fun. Thanks!
