I followed this thread because I am having similar issues with my pool. I have a 40x20 inground pool with a Hayward Perflex EC65 DE filter. My pool has 4 return jets, 1 in each corner of the pool. I have two skimmers, 1 on either side of the pool, and I have 2 main drains at the bottom. For the past week, I go out to the pool and the returns are barely pushing water and if I pull the skimmer baskets out and put my hand over the suction, it barely sucks. the pressure on the filter is about 15PSI. If I shut my filter off, bump the handle 3 times and turn it back on, the return pressure and the skimmer suction is perfect as it should be. the pressure on the filter is about 10PSI. About and hour later, the pressure on the filter is again at 15PSI and the return pressure is very little and there is very little suction. I have backwashed the filter, removed the filter and soaked it with a cleaner for 2 hours, hosed off the fingers and put it all back together and the results are the same every hour or so. What is causing this for my system?
