Goldline AquaRite No Power LED - Current Limiter Fried
Aquatica
Platinum Supporter
512
Nassau, Bahamas
Just thought I'd share this. The local power company fried the current limiter on an aquarite. see black disc on right...
New board costs $200+...new current limiter only $3!
We are replacing the $3 limiter..
http://www.facebook.com/photo.php?fbid= ... =1&theater
btw all other displays are working. fuse is good. this is why. but power led off. and you can see a crack on the limiter and also the connections burnt.
more info on this fix can be found here: http://www.manulabo.com/Hayward/aqrpoweren.htm
I actually have an Aqualogic unit not an Aquarite product but will check this out in the morning. My control unit is also working fine. I may also swap a couple relays around and see if that has any effect too. out. If anyone else has any ideas too I'm all ears. Thanks.
Steve
Has anyone applied the current limiter replacement solution to a Hayward Pro Logic PL-P-4 motherboard? I have all the same symptoms but the current limiter is yellow and I'm afraid it might not be the same as in the AquaRite systems. Thanks!
