Well we are getting toward the end of this pool building process and need to decide on the pool controls. The pool builder said that we really need switching for 13 different things. So He is suggesting the intellitouch system with the biggest expansion kit due to this requirement. I was able to keep up with most of your advise and other post with regard to other equiptment but I'm pretty lost on this system. We have 4 pumps: 1 vs for the pool, 1 3hp for the waterfalls, 1 booster for the spa, 1 for the pool cleaner. Two blowers for the spa. Two majicstream laminars. And independent lights for the pool and spa. I'm not sure on the valves but there is a bunch. My question is how do you like to control your pool? do you like to be able to turn stuff on from work, on the way home. Do you change stuff a lot when your swimming. If I do the intellitouch with my Ipad as the only remote and my network goes down. Will my pump and other stuff still work? My pool bid has an Easytouch system on it and this upgrade will cost an additional $4100 dollars . Does that sound right. I was on the phone at the same time the PB was on the phone with the rep and he was giving us the straight cost pricing. If you were me how would you do it? I can afford the extra expense but If I don't need to I would like to put it elsewhere. Thanks for setting me straight. Steve
